wow just found this article too on this player:
http://www.it.com.cn/f/audio/081/3/530763_1.htm
it says the player may support upto 32gb microSD card!!! Also check out this image of the UI:
Specs from article:
* 3.0 inch, 400*240 □□the real color TFT □screen □shows the screen; All touches the screen operation.
* Supports MP3, WMA, WAV and so on the many kinds of sounds □form; Supports the APE/FLAC □□□□sound □;
* Support song □synchronization □shows;
* Supports RM/RMVB, ASF, AVI, MP4, 3GP, MPG and so on each kind of form □□broadcast;
* Support rich You?;
* Supports the FLASH □□broadcast;
* Supports form □piece and so on the JPG, BMP, GIF, PNG □□, turns on lathe □and the imaginary □piece broadcast;
* The Fm reception and may save □more than 40 □□;
* □sets at □the gram □, ultra □□□□sound;
* □can □set at, the typeface □color, □shows brightness, the contact surface background and so on is free □sets;
* 8 kind of EQ sound effect, may supply to follow □□□;
* The support □sub- □□□, □stands □□, from □□□the function;
* Supports WIN98SE/ME, WIN2000, XP is □;
* USB2.0 high speed □□connection;
* Biggest support high speed 32GB Micro SD (TF) the card □unfolds saves □is spatial □;
* □□limits rises □;
