It is currently Wed Jun 19, 2013 10:19 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Mon Jan 14, 2008 10:42 am
i found this stuffs on the bbs of the GEMEITECH's web site.
NOTICE: this is not official firmware even for X760
http://www.51ok.com/filedown-803925040.html
download by clicking green colored down-arrow.
(this also contains window vista initial screen.)
i don't know all of changes in this firmware but
i figured out there is improvement of WMV/ASF features.
WMV/ASF works well which means
they are well fast-forwardable and save/load able instantly.
these functions response very quickly. cannot see any skipping nor chopping, blinking..
i have encoded using Ultra mpeg-4 converter with 'wmv2 (wmv 8) and wmav2.
there can be some uncomfortable issue about codec problem.
anyway, it's obviously true that the stuffs works on me well.
try findng your own setting.
 Post subject:
PostPosted: Tue Jan 15, 2008 4:20 am
Thanks for this.
I have loaded this onto my 301 and it works great. Cant say I've noticed a huge improvement on a quick test. The 'Google Maps' app is there but I havent tried to load anything yet.
PostPosted: Tue Jan 15, 2008 8:39 am
Well, I just tried this firmware v10.01 for the X760 on my JXD 301. Here is my assessment of it. Take it as you will.
Pro:
--The interface seems to be more responsive and more instant. With the original 301 9.3.6 firmware there was a small delay when you hit the buttons and then it goes to that corresponding menu. With this X760 firmware it seems to be navigating is a little faster.
--Video files tend to load up faster and even the Fast Forwarding and rewind tend to be faster especially with the WMV files.
--You have all the basic functions and even FM tuner, however, it doesn't do anything on the JXD 301. But it will pretend to make an attempt on the unit. :wink:
--Music works like it should, its pretty fast going from one song to the next. It exits and start and stops like it should.
--Pictures are also working like they should. They seem to render a little bit faster. Not much though.
--You do not have to ADD anything to the Music,Video, etc.. directories within the player(like you do with the 301). As long as you put it in the corresponding directory, it will show up. That to me is nice.
Cons:
--Obviously some of the keys do different things as it is made for a different player. However, for the most part it is tolerable.
-- To me the Video may load up faster, however they seem to play more slugish with this firmware VS the 301 firmware. Especially the Real media RMVB files, they load up and fast forward good, but It seems to drop a lot of frames, something that didn't happen for me with the 301 firmware.
--Yes, this will play WMV files, however, it was hit and miss. Some would play just fine while others would play halfway through and then just exit for no reason. Sometimes I could fast forward past that point and other times it would just exit me out to the main menu. And I had tried multiple WMV rendered videos, so there didn't seem to be a pattern to it.
--Default theme is kind of stupid, however, it is not bad. I'm just spoiled with the Apple theme and others that were created by another user on these forum's.
--Game emulation still kind of sucks, in fact it seems more sluggish with this firmware.
Overall it is not bad, especially for music. However, I think that I will go back the 301's firmware. While the interface is a little bit faster navigation wise and execution wise, to me it just isn't worth the video performance hit that I am getting plus the unstable WMV's. Remember, these are MY experiences with this firmware. Your millage may very, however.
I just thought I would share.
"Sega Announces that the DreamCast 2 is to be released along side of Duke Nukem Forever......."
 Post subject:
PostPosted: Tue Jan 15, 2008 8:40 am
I just put this on my JXD301...
It's kinda weird.
The startup screen says "Windows Vista" with the windows logo center screen, which then changes into some chinese guy after a second. What's even weirder is that the default theme is Apple-styled, complete with the Apple logo in the upper left corner. The unofficial branding doesn't stop there however, strangest of all is the "Sony" logo in the lower left corner of the music player.
Inexplicably the title bar of every application now simply says "Cool".
There are two new icons, GPS (I'm guessing from the file name of its graphic- it isn't labeled and I couldn't get it to do anything) and FM Radio (which doesn't work obviously).
If you don't watch video on your player there's really no reason to "upgrade".
 Post subject:
PostPosted: Tue Jan 15, 2008 9:10 am
Thanks for the info guys. I've decided not to try it for abvious reasons stated on your posts. Hopefully JXD will fix some of the issues with the x760 but Im not sure they will. And since they are not manufacturing the 301 ( for now ) I doubt they will upgrade its firmware.
Too bad.
 Post subject:
PostPosted: Tue Jan 15, 2008 4:02 pm
The latest 'official' Gemei firmware has the similar theme but without the Vista/MacOS 'branding' and the 'Cool' and little paw print. I cant see it being a problem copying over the better stuff from the older firmware.
on the plus side, atleast they are still 'improving' this firmware...
I havent investigated fully but I dont think the other custom made themes work on this firmware since it moves left/right not up/down. When I tried a few of them they were all messed up.
