It is currently Sat May 18, 2013 7:50 pm
Post new topic Reply to topic  [ 3 posts ]
 Post subject: VX767 questions?
PostPosted: Tue Aug 05, 2008 1:18 pm
Got my 767 today. For a less then one day trial it seems pretty good. Seems to play well every video I throw at it. It does have one dead pixel tho. Have not yet recharged it so I will reserve judgement for awhile.
I have a few questions about the 767. Can you get rid of the timers that run while playing videos? How do you go to the main menu when you are playing a video? I press the return button, but it only changes the video size.
I tried to upgrade the firmware, but never got the upgrade screen. I have the HXF file in the root directory. I press and hold the - key, then press the play pause button, but it only turns the player off. I'm just glad I didnt brick my brand new player.
Can the 767 use a battery pack? Music doesnt sound too bad on the 767 from the songs I heard on the player. Wish it would play ogg files!
 Post subject: Re: VX767 questions?
PostPosted: Wed Aug 06, 2008 7:37 pm
Ok, I have the answers to my first two questions. Still need answers to the other ones.
tia
PostPosted: Thu Aug 07, 2008 12:31 am
Make sure that your player is turned off and then push down on the buttons.
As for the battery pack, the player can use it to run off, but it can't charge of it (unless you can find an adapter to connect via USB to the players power adapter input).
