It is currently Wed May 22, 2013 4:58 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Mon Feb 13, 2012 6:16 am
Does anyone have a link to the firmware for the Rena3 that MP$Nation sells? I received mine last week and it has frozen.
Thanks.
PostPosted: Tue Feb 14, 2012 7:04 pm
I have opened a ticket asking for the firmware. How long does it normally take for them to respond?
PostPosted: Tue Feb 14, 2012 10:59 pm
Here you go, http://www.slatedroid.com/forum/206-ren ... velopment/
Take some time read and learn before you do upgrade the FW.
Search is your friend. ;)
HDVP-2 review
T11rk v1.9.14 upgrade guide
My Rig
My MIDnite mini review.
VX610 upgrade guide.
PostPosted: Wed Feb 15, 2012 1:03 am
Thanks for the caveat, and I will heed it from now on. What I am trying to get is the original firmware to fix an attempted upgrade using an incompatible firmware.
I had no idea there would be more than one firmware for this type of tablet.
PostPosted: Wed Feb 15, 2012 1:45 am
Read through and learn. , I'm sure there are original FW there. can't remember which thread, I saw it long time ago.
HDVP-2 review
My Rig
PostPosted: Wed Feb 15, 2012 7:13 pm
ok...I have it fixed, AND updated to Android 2.3.5
I found a Chinese tablet webpage and had to put the 2.3 Android file in with another OS installer files. Oddly enough, it seems to work great!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
