surplus4u wrote:
Curious about others experience - how durable the trackpad has been for you guys/gals?
I just got mine about 11 days ago and it already not working properly.
it will not scroll in the right and up direction.
any suggestions to fix this?
Clean it, first try just a damp [not wet] lint-free cloth. Holding the Rocktab face down, roll the trackball in all directions on the cloth.
Failing this, try a cotton swab and isopropyl alcohol (100%) with no additives or coloring. Be very careful and use the alcohol sparingly. Do not let the cotton fibers roll around the ball, it will only make things worse. This you will do with the Rocktab face up, applying slight pressure with the swab on the ball rotate it and move it across the surface simultaneously. Hopefully you will see bits of fluff come out, clear this away before continuing.
Either way it may take more than a single cleaning to restore full function, the rollers that track the movement of the ball get covered and slickened by residue on your fingers. Wash your hands and keep them clean when you are using the Rocktab to avoid build-up inside.
