It is currently Tue May 21, 2013 2:59 pm
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
 Post subject: How is the music quality
PostPosted: Wed Oct 20, 2010 5:12 pm
Hi there,
I'm thinking of ordering a MIDnite but the music quality is important for me.
I now use a nationite OS-43 :D witch is very good for music.
Has anyone have experience with the music quality on the MIDnite, please let me know what you think about it!
Thanks,
10i
PostPosted: Wed Oct 20, 2010 5:44 pm
There is so much that involves good sound quality.
Here is some of my observations:
1. With the right APK you can stream music from your UpnP-server which is a GREAT plus for me.
2. You cannot connect Alphas (and probably not M1/M2/M3's either) to it. Beacuse the audio jack is set deep into the side. You then need a converter or special audio cable between headphones and MIDnite, which will lower sound quality.
3. I have connected it to my usual stereo speakers with subwoofer, and it sounds just as good as when I use my computer (maybe even a bit better ie. lower SNR).
So it is really quite difficult to say if you will be satisfied with the audio quality.
All I know is I like it, when using my normal speakers that I am "used to", and beacuse of all the "features" it offers with APK's.
On the other hand I did not like the sound of the Alphas that came with it, which everyone else seem to like, so... :) Well I hope you get my drift :roll:
http://www.AndroMIDs.com - Firmwares, Custom ROMS, apps, howtos for the MIDnite and other Android MIDs.
Current setup:
MID: Nationite MIDnite (loving it (did after 5 minutes))
Portable Musicplayer: Nokia 5800 with Philips Bluetooth headset, Onda VX530 (mostly used by my daughter)
Video and Music player: Laptop with radiolink to multiple speaker systems, also Bluetooth connection to speakers (Belkin bluetooth reciever)
Nationite HDVP2 streaming from a Server with 2,5TB of music, movies, tvseries and photos via TVersity (trying it out)
PostPosted: Wed Oct 20, 2010 6:10 pm
Hi sourcery,
Thanks for your reply.
I understand that its very difficult to determine if I like the soundquality of the MIDnite.
What's important for me is that there is no strange hum or noise when playing music and that the used opamp is capable of giving a good signal to the headphone.
I won't use the Alphas (there nice but sound not very open) ,but Soundmagic and a very good Sony headphone.
10i.
PostPosted: Wed Oct 20, 2010 6:18 pm
Sound quality is reasonable.
PostPosted: Wed Oct 20, 2010 7:45 pm
It has a cirrus logic dac, the sound isn't bad, there isn't any hum or hiss, but your music play experiencing may depend on the app use as there are good music apps for Android and then there are the not so good ones.
PostPosted: Wed Oct 20, 2010 7:54 pm
That sounds logical :) .
Anyone for tips on witch app to use?
I play mostley MP3 and FLAC.
Thanks!
10i
PostPosted: Sat Oct 23, 2010 12:19 am
The speakers are passable at best, IMO. But I use some basic Creative headphones with the RockPlayer app that was already installed (accessing music I had copied onto a micro SD card) and I thought the quality was actually pretty good.
PostPosted: Sat Oct 23, 2010 12:42 am
DoubleTwist on Android is amazing. I was playing with it yesterday on my friends phone. If you can get that on the MIDnite then you should try using it for music playback.
Home Viewing: Assassin HTPC (i5 3570k 3.4 GHz w/ HD 4000) + Samsung UN32EH4003
Portable Audio: Cowon J3 + Brainwavz M3
Portable Video: Google Nexus 4 + Brainwavz M5
Other Toys: WDTV Live Streaming, Xtreamer SideWinder3, Sansa Clip Zip
How to Encode: Blu-Ray to HDVP-2 | DVD to HDVP-2 | DVD to S:Flo²
How to Get Help With: Files That Won't Play | Remuxing An MKV File
Tools: MakeMKV | DVD Catalyst
PostPosted: Sat Oct 23, 2010 12:43 am
It isnt bad, neither is it good either, just don't expect stellar SQ =)
PMPs: Cube B33FHD, Ainol V9000HDA, Ramos T12
MP3 Players: Cube C30, Sansa Fuze, Nationite Nanite N1
MIDS: Nationite MidNite
Heaphones/Earphones: Fischer Audio Eternas V1, Koss Sportapro, Soundmagic PL-30, Soundmagic P20 Sennheiser MX580, Creative EP-630
PostPosted: Wed Oct 27, 2010 5:32 pm
I just ordered a MIDnite so I can experiment with it.
Thanks for all the replys!
10i
