It is currently Fri May 24, 2013 11:42 pm
Post new topic Reply to topic  [ 8 posts ]
PostPosted: Thu Dec 02, 2010 11:45 pm
Any ideas on how to get back to English on my ACHO C901.....it has reverted back to factory defaults and now everything is in Chinese.....HELP!!!!
PostPosted: Thu Dec 02, 2010 11:58 pm
It normal can change in setting, can you post the pics after you tap the setting? I can help you from there.
HDVP-2 review
T11rk v1.9.14 upgrade guide
My Rig
My MIDnite mini review.
VX610 upgrade guide.
PostPosted: Fri Dec 03, 2010 12:13 am
Bottom of the first post here: viewtopic.php?f=69&t=20158
PostPosted: Fri Dec 03, 2010 12:40 am
Thanks poet, but I can't see the Language option there.
anyway, @gpeiffer, I'm not sure what's in order, if you tap the ???settings) from home menu, select ???language?? select ???English??hope it helps.
HDVP-2 review
My Rig
PostPosted: Fri Dec 03, 2010 6:15 am
Then you're blind, lol. It's at the bottom of the first post:
"Back To English:
To return to English after updating, you have to go to:
Settings (its in English on the main page), press it, Scroll down to the 7th button on the left, press it, Press the Top button on the right, Then press "English", done :) (Thanks dragon2knight)"
PostPosted: Fri Dec 03, 2010 7:07 am
nah..I was looking at the pictures not the text..lol Head doesn't work properly yet after first coffee. :lol:
Yep, I did a blind job, you see... :mrgreen:
HDVP-2 review
My Rig
PostPosted: Fri Dec 03, 2010 9:55 am
Location: Da Bronx, New Yowk, in Da United States of 'Merica
:roll:
Ainol NOVO 7 Elf II 7" 1024x600 Capacitive Screen, 16 GB of memory, 1GB of Ram, 32GB microSD card, Dual Core, Android 4.0.3 with the Custom Dark Elf Rom. VIDEO REVIEW: http://www.youtube.com/watch?v=XpsSK5G0XMo
UG802 Android On A Stick HDMI based Android TV Device. 1080p Video, 4GB Ram, 32GB microSD card, Android 4.1.1 Jellybean, Rockchip 3066 Dual Core. VIDEO REVIEW: http://www.youtube.com/watch?v=2gqd1AjJm60
PostPosted: Fri Dec 03, 2010 9:58 am
Then get coffee first dammit. :mrgreen:
