It is currently Sat Nov 21, 2009 10:17 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: [REVIEW²] alpha + beta Brainwavz
PostPosted: Fri Jun 26, 2009 3:23 pm
Casual nationite
Casual nationite
This review can also be found @ Head-fi.
First, wanna thanks Raz for giving me the chance to review the beta Brainwaz. Since the alpha Brainwaz is included with the sample of beta, I thought I'll review it as well. Keep in mind that both IEM are in OEM package, and beta hasn't received its final packaging yet, so you should expect better packaging and more accessories after its official launch, which I guess is pretty soon (estimated to be early July).
alpha Brainwavz
As the first generation Brainwavz, MP4 Nation's aims alpha as the cure of the common stock-earbud-syndrome. For that, they decided to work with well known Chinese manufacturer to introduce some of the best-bang-of-the-bucks models in China to the rest of the world under MP4 nation's own 'Brainwavz' brand name. Long story shorts, that is how alpha comes to life.
Spec
Driver: Single 8mm Dynamic
Sensitivity: 100dB SPL @ 1 kHz
Impedance: 20Ohm @ 1 kHz
Frequency Response: 15Hz - 28 kHz
Cord: 1.26m
Rated Power: 10mW
Max Input Power: 30mW
Plug: Gold-Plated Stereo 3.5mm Mini-Plug
Packaging, Accessories, and Build Quality
alpha comes with a no thrill, OEM-like packaging with three set of different sized single flange eartips, probably similar to the bundle package comes with MP4 Natin's own brand of PMP. Since it is very much a budget oriented IEM, I guess there isn't anything to complain about. For similar price, you will find SoundMAGIC offering better packaging and accessories. Build quality wise however, alpha seems to be stronger and more durable. Microphonics is slightly worst than average, but nothing too terrible that an extra shirt clip won't fit. Isolation is average. Decent for daily use but not for the noisiest of situation
Sound Quality
I gave alpha a 100 hrs burn-in before the auditioning, but I couldn't say in definite that it improves the sound quality. Maybe the are some changes, but probably not very obvious.
alpha's sound signatures are on the warm to slightly dark side. Big bass, heavy mid, and not very detail on the treble but still have a tiny bit of sparkle. Despite the fact that the overall sound feels slightly congested due to the heavy mid, the bass actually has quite a good resolution and texture to it. Vocal is pretty forward and dominant. Upper treble rolls off early. No sibilance to speak of. Soundstage is small due to the lack of fine detail and airiness. Overall, alpha Brainwavz is slightly dark with a very mid and bass centric, fun and more personal sound
Conclusion
For about US$14~16, alpha Brainwavz is in the same line of fire as the SoundMAGIC PL11 and PL20. PL20 is good on detail but lean on bass while PL11 is more bass oriented. Both has better soundstage and detail than alpha. However, alpha has better bass performance and sweeter vocal. SQ wise, I consider them to be just about the same. It is definitely one for the basshead with small budget.
beta Brainwavz
beta comes not as a replacement of alpha, but more of an evolution. If I am not mistaken, this pair of IEM is also from a Chinese IEM maker. Those who are in China might have seen a very similar IEM on the street or over the shop counter. Nevertheless. MP4 Nation is giving the IEM an updated look and a new set of accessories for its international debut.
Spec
Driver: Single 11mm Dynamic
Sensitivity: 110dB SPL @ 1 kHz
Impedance: 24Ohm +/- 10%@ 1 kHz
Frequency Response: 8Hz - 28 kHz
Cord: 1.20m
Rated Power: 10mW
Max Input Power: 40mW
Like the alpha, beta also came in a pretty OEM looking packaging - but no need to worry here, as final version will have a box and a few more accessories. The final version will have a pair of orange cone silicone eartips, a pair of translucent white cone eartips, a pair of big bi-flanges, a pair of orange foam eartips, shirt clip, a fish bone shaped cable winder, a pair of removable metal mesh and a soft pouch by Mofi. A few things worth noting: 1) beside the foam tip, none of the other eartips can be considered for small ear canal and 2) The Mofi pouch is actually quite good.
beta's nozzle diameter and length are a bit of the odd side. Diameter wise, it is larger than those found on Shure or Westone, but smaller than the UE. If you want to use aftermarket eartips, you can use Shure's eartips if you don't use the metal mesh. If you do have the metal mesh on, you can use a tight fitting UE style eartips like the Sony hybrid replacement eartips, but not the loosely fitted genuine UE eartips. For foam tips replacement, I can fit a Comply T100 on beta when the metal mesh is off. So you wonder what is the big deal about those metal mesh? They are actually used for sound tuning instead of earwax stopper. More on this later.
(left: no mesh)
Beta appears to be well built. The wire is pretty soft yet seems to be strong. The nozzle of the earpiece is made out of aluminum alloy, individual marked with serial number (for QC and warranty, if I am not mistaken). The metal mesh can be screwed on or off based on the user preference. There is also an one inch transparent sleeve over the cable where it meet the earpiece, protecting the weakest part for wear and tear. Microphonics is very good while isolation is average. Overall, I think the build quality has vastly excessed its asking price. The finished version is said to have even better looking.
Sound Quality
As suggested by MP4 Nation, I burnt the beta in for 100 hrs before the auditioning. Like the alpha, I didn't notice any major change in sound quality.
beta's sound signature with the metal mesh is balanced but on the warm, smooth side. Bass extends quite further down but lacks big body or impact. Mid is full and warm. Treble performs well, capable of showing a good degree of fine detail. Soundstage is about average. Without the metal mesh, bass definition suffers a bit while the upper mid and treble become more forward, brighter with more fine detail. Soundstage is also very slightly more airy.
In sum, beta with the mesh has a well balanced sound without any major strength or weakness. Its sonic characteristics resemble that of CrossRoads Woody 2, but in a lesser form. Without the mesh, beta becomes brighter sounding.
On a side note, my beta also comes with a FiiO E5 as part of the bundle. Personally, I find beta to be just fine without amping, but pairing with the E5 can gives you more bass if that is what you crave for, since beta is more on the balanced side instead of the alpha's big bass side. For the least, I don't find any synergy issue between them both.
Conclusion
beta is an major upgrade from the alpha, both on build and sound quality wise. People with tight budget will not be disappointed by the beta, especially consider it high performance / price ratio. It is one of those IEM that are fully capable on taking down many other that have double or even triple the price tag. Those who are looking for the best bang for the bucks should put this one high on your list of consideration.
For a quick sum up on both IEM, read this.
[InEarMatters.net] : Earphones' news and reviews
 Post subject: Re: [REVIEW²] alpha + beta Brainwavz
PostPosted: Fri Jun 26, 2009 3:30 pm
Supreme Nationite
Supreme Nationite
thanks ClieOS for detailed review :D
PostPosted: Sun Jun 28, 2009 4:26 am
Fanatic Nationite
Fanatic Nationite
I have a couple of sets comming to me (the E5 bundle). I'm hoping that these will make a good vualue for gift phones for this up comming holiday season. Thanks for the review. ^_^
PostPosted: Sun Jun 28, 2009 1:19 pm
Site Admin
Site Admin
thanks agaim ClieOS for your review on our earphones, good to see that you generally like the sound quality of the Betas, i certainly consider their sound to be well balanced, but i do like using it with the E5 to kick up the bass. I prefer to use my Betas without the mesh, it gives for a better sound overall than when i use it with the mesh.
Audio: Nationite NaNite N1 4GB (Black) + BetaB
Video: Nationite OS-72HR 8GB + BetaB
What do you use? Check out my Rig Pictures
Follow MP4 Nation on Twitter
Have a order related question?
PostPosted: Mon Jun 29, 2009 7:52 am
Fanatic Nationite
Fanatic Nationite
So Raz, when are you going to start selling the nice bi-flanges that come with the beta's? I've been using those for a couple of yers now and I love them. I would like to buy a good 1 or even 2 dozen sets. Just at a reasonable price.
PostPosted: Tue Jun 30, 2009 3:04 am
Supreme Nationite
Supreme Nationite
Just to catch the wagon, I would love to see it on store too, Raz! If there is a reasonable price on it, I would buy 1 or 2 dozen, too!!! :D
PostPosted: Tue Jun 30, 2009 4:34 am
Supreme Nationite
Supreme Nationite
ClieOS, how did you manage to get these headphones?? I want to sign up for the review team!
Now-for a breath I tarry
Nor yet disperse apart—
Take my hand quick and tell me,
What have you in your heart.
Speak now, and I will answer;
How shall I help you, say;
Ere to the wind’s twelve quarters
I take my endless way.
PostPosted: Tue Jun 30, 2009 5:44 am
Casual nationite
Casual nationite
Raz found me this time. I have been reviewing IEM on Head-fi.org for a while, either samples from different companies or bought with my own money - that and a lot of time. Beta will be the 32nd IEM I reviewed, 33th is currently being wrote up while 34th is on its way to me. It is a very costly hobby I'll tell you.
PostPosted: Tue Jun 30, 2009 7:53 am
Insane Nationite
Insane Nationite
Hope that the gratitude of your readers at least partially offsets the time and money you have invested in your IEM appraisals :).
Oh yeah, thanks. Great review.
PostPosted: Wed Jul 01, 2009 2:01 am
Supreme Nationite
Supreme Nationite
Oh, OK. I was just curious, especially considering you only having 13 posts currently. I could understand why it would be an expensive hobby. At least headphones don't become outdated tech, right?
PostPosted: Wed Jul 08, 2009 3:16 pm
Casual nationite
Casual nationite
For those who are interested, Anythingbutipod.com has a beta Brainwavz review as well.
http://www.anythingbutipod.com/archives ... review.php
PostPosted: Wed Jul 08, 2009 4:42 pm
Insane Nationite
Insane Nationite
They don't treat them with kid gloves.
What surprises me is that the reviewer ranked them below the CX300's as far as SQ goes.
BTW, great review on the new Sound Magic PL-50 IEMs Clieos.
PostPosted: Thu Jul 09, 2009 12:18 pm
Casual nationite
Casual nationite
Review is all personal. Take CX300 for an example - It has quite a shrill high and bloated bass (V shaped frequency response). I can listen to it for a short while, but in the end I just can't stand it, hence I rated it to be very low. However, for those who can enjoy that kind of sound signature, I have not doubt that they will totally disagree with my rating.
Different reviewers will look for different characteristics and give a rating based on their finding. It is up to the readers to determine which reviewer has a preference closer to their own and so which review to put more weight into. For example, I have no confidence on CNet UK headphone review what-so-ever since I always find myself having a totally different opinion to the IEM they have reviewed.
PostPosted: Thu Jul 09, 2009 6:33 pm
Site Admin
Site Admin
Earphone sound is very subjective, its like when you meet a guys who wife sounds like a harpy but he thinks she sounds like an angel, its all about what you like and that differs from every person.
It good to have reviews from all parts of the spectrum, i like ABI review, its very detailed and he does point out the good and bad, just like ClieOS did, in the end the more reviews there are for the Betas, the better people can understand them before they make a purchase.
I think the betas are quite good, i wouldn't have put the time or effort into branding them, boxing etc if i didn't think people would not enjoy them.
PostPosted: Thu Jul 09, 2009 11:50 pm
Insane Nationite
Insane Nationite
@Clieos & @Raz
True enough, it's a subjective experience.
I'm looking forward to listening to my ears' opinion on the matter ;).
Search for:
