It is currently Sun May 19, 2013 11:29 pm
Post new topic Reply to topic  [ 8 posts ]
 Post subject: Newbie here
PostPosted: Wed Apr 29, 2009 3:54 am
How do I make it so my PC can detect my new VX787?
I'm running Windows 7, if that helps any.
 Post subject: Re: Newbie here
PostPosted: Wed Apr 29, 2009 4:00 am
hi and welcome
well windows 7 is certainly alot better than the vista and has been proven to work with these player
try using a USB port at the back of the PC if you are not doing so
what happens to the screen when you plug it in, does it go right to charging screen
PostPosted: Wed Apr 29, 2009 4:06 am
It goes right to the screen that says USB in the middle.
PostPosted: Wed Apr 29, 2009 4:08 am
yep, classic problem, a powered USB hub can fix this as can using the back USB ports or swap around also try a reboot of the machine and if you have access to an XP machine then test it on that to see if it is the cable that is the problem
cheers
PostPosted: Wed Apr 29, 2009 4:35 am
Yeah, the XP machine detected it no problem, I'll get it working now.
Thanks, Manderin.
PostPosted: Wed Apr 29, 2009 5:04 am
no probs mate, just ask if you need anything, generally they all function in a similar manner
cheers
maderin
PostPosted: Wed Apr 29, 2009 5:06 am
how did you get it working? might be interesting to other users
Nationite OS-81 4GB
PostPosted: Wed Apr 29, 2009 5:41 am
I just restarted my computer like Manderin suggested. Windows detects it just fine now.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
