It is currently Mon Sep 06, 2010 8:34 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: :: VX787 :: Themes :: Simply Blue ::
PostPosted: Mon Oct 27, 2008 11:25 pm
Supreme Nationite
Supreme Nationite
This is a copy of Maderin1's "Simply Blue" theme which is now the standard theme on all new Nationite S:flo's.
It was my intention to simply copy most of the design and images over to the VX787 but in the end I had to re-produce most of it due to the sizes, format, etc..
A very big thanks to Maderin1 for allowing me to use this theme and for the fantastic job you did in designing it, I have named the theme after you to show my/our appreciation.
The download contains the resource file " BMP0.BIN " and the file to reveal the hidden firmware drive/partition " rkusb.tag "
To upgrade you're players theme you will require access to the players firmware partition which is very easy, simply copy the rkusb.tag file into the root of the players media drive ( the space outside the folders ) then switch the player off / on, when you re-connect the player to the computer you will see that there is now an additional drive showing.
If you look in the new drive you will see a folder structure ( x4 folders ) . Locate the folder " RESOURCE " and look inside it, you will see another folder " BID " , this is where the resource file " BMP0.BIN " is located.
To update the theme simply replace the existing " BMP0.BIN " file with the one you downloaded.
To change the language correction file you will have to replace the existing one which is also located in the " RESOURCE " directory but in the " SID " folder.
I have also uploaded another new theme, "T8-Inspiration mkII" please have a look -
LINK
See also the following guide on how to access the firmware partition -
Accessing The Hidden Firmware Partition - Link
Maderin-One S:Blue Theme DOWNLOAD
English Translation File
EDIT:
This theme is for the Onda Firmware Version 1.8
This is a complete theme including a new design for, User EQ, Music, Menus, eBook, Photo, Video...
Thanks Maderin1!!
 Post subject: Re: : : VX787 :: Maderin-One S:Blue Theme : :
PostPosted: Mon Oct 27, 2008 11:29 pm
Online
Moderator
Moderator
WOW ... many thanks for the name check there and without sounding big headed .. it look really good .. so far
would love to see a vid of this in action
i am assuming its 1.8 version ??
well done seasprite, another FANTASTIC job (and i am not referring the the design as much as but to all your efforts)
you are the vx787 modding master ... well done mate 10/10
Custom dock icons | The Rockchip modding Guide and Tools
OS72HR ::hints tips tricks, links reviews and more
S:Flo² ::hints tips tricks, links reviews and more
PostPosted: Tue Oct 28, 2008 1:43 am
Learning Nationite
Learning Nationite
Ah YES!
Awesome job seasprite, especially coming from a blue-fan here. (of course, thanks go out to Mandarin as well)
I haven't even downloaded anyone else's themes since 1.8 came out, I've just waited for an official post from you.
EDIT:
I recorded a short video of mine with the new theme on it, link will be up as soon as the upload is complete.
My Phone: Sony Ericsson w580i
My Video and Audio: Onda 787 (Thinking of selling. Not sure if I'm supposed to post that on this forum though...)
PostPosted: Tue Oct 28, 2008 3:02 am
Learning Nationite
Learning Nationite
http://smg.photobucket.com/albums/v313/ ... Video2.flv
Sorry for the bad quality, my camera died so I had to use the old webcam.
My only complaint is that the language hasn't been fixed. Can I just use the language fix you did on the 1.7 firmware?
PostPosted: Tue Oct 28, 2008 3:13 am
Supreme Nationite
Supreme Nationite
Yes, the language file should be used with this theme.
In order to keep the file small for downloading I only supplied the theme file.
Thanks!!
PostPosted: Tue Oct 28, 2008 3:24 am
Supreme Nationite
Supreme Nationite
The theme works best with the first three backgrounds as they were taken from the original theme.
Did you notice the new User EQ settings and the music display/EQ ?
I also changed the eBook background and added the top bar.
And loads, loads more...
PostPosted: Tue Oct 28, 2008 1:42 pm
Learning Nationite
Learning Nationite
VERY COOL! You guys are excellent! Many THANKS!
PostPosted: Tue Oct 28, 2008 1:44 pm
Regular Nationite
Regular Nationite
Seasprite
The english translation file you created for 1.7 will work on firmware 1.8?
PostPosted: Tue Oct 28, 2008 3:45 pm
Casual nationite
Casual nationite
Wow look great, i like the icons :D.. Thank you very much Seprite and Manderin1!!! ^^
PostPosted: Tue Oct 28, 2008 5:11 pm
Online
Moderator
Moderator
Godot wrote:
http://smg.photobucket.com/albums/v313/minataku/?action=view&current=Video2.flv
thanks for the video, it shows how much work has been put into this theme and whilst i am very happy to hear thanks from people with regard to this theme, its all seaSprites work
ooks really good, totally different player
PostPosted: Tue Oct 28, 2008 5:21 pm
Newbie Nationite
Newbie Nationite
This is GREAT :D
Thanx very much!!!!
PostPosted: Tue Oct 28, 2008 7:40 pm
Supreme Nationite
Supreme Nationite
sonicboomin wrote:
Seasprite
Yes sonicboomin, the current English translation file is totally compatible with all firmware versions including the very latest v1.8 firmware. I have added a link to the file at the top of this topic.
English translation file link
 Post subject: Re: : : VX787 : : Maderin-One S:Blue Theme : :
PostPosted: Wed Oct 29, 2008 10:19 pm
Supreme Nationite
Supreme Nationite
Has anyone else tried this new theme yet?
If anyone has it installed could they help by posting photo's or video's of it, please :D :D
Thanks!
PostPosted: Thu Oct 30, 2008 4:54 am
Casual nationite
Casual nationite
Thanks!
Godot did this on the #4 post :D
PostPosted: Thu Oct 30, 2008 5:10 am
Learning Nationite
Learning Nationite
I can get some pics up a little later. Is there any big specific highlights you want me to show, Seasprite?
Users browsing this forum: Google [Bot], Nate Velasquez and 2 guests
Search for:
