maderin1 wrote:
excellent work seaSprite look like a totally different player
did you use the explorer tool to make the compiled file?? and it all worked OK, i have been tenpted to try this as i think it is a much better way for most users to update rather than accessing the bloody hidden partition, especially for the s:flo firmwares
also would it be worth trying to copy into the new compiled file a version of the BASE.rkw files from your player once you have set it to english and then it would be preset ??
good work,
Yes, I used the editor to compile it as I had changed that many things, the theme worked out not bad but the goal here was to make the player better/easier to use as a lot of images were not aligned with the touch area's, this now gives me a base to go on and do something better, I wouldn't mind trying to use you're simply blue theme as a base, would that be alright?
The images here do not look that great but on the player it is much better and with 14 backgrounds to choose from I think most people will like it
I never thought about trying the base.rkw, I will try it now and let you know
