DO NOT UPDATE YOUR VX858 ONDA CLONE PLAYERPlease anyone who has a player like this in the image below and it DOES NOT SAY ONDA on it the DO NOT TRY AND UPDATE THE FIRMWARE
YOU WILL BREAK YOUR PLAYERIf you have a player like this and you have come here looking for firmware then
please think twice, there are so many different versions of this player made by many different factories at the moment that there is
no definite way to tell which firmware you have on your player.
we
can not and will not guarantee these firmware on out forum will work
At the moment we are seeing alot of people who have tried to update and are now seeing there player screen
inverted and mirrored,if you have bought a player that looks like this from ebay or another store and you feel it is not working right then DO NOT try and update the firmware to fix it, contact your seller and tell them you want to return it or ask them for an update, if you try and update it and all goes bad then you will not be able to send it back, so contact the person you bought it from FIRST
It is heartbreaking to see people come here and ask for help but at the moment the only way to even try and recover a dead player is to
CONTACT YOUR SELLER
DO YOU HAVE A CD WITH YOUR PLAYERThen odds are it is a generic cd and you can not trust the files that are on the CD, if you see a firmware file on it i would recommend not trying to update your player with it. The cd disks sent with these players from ebay etc are often wrong and not specifically for the player you have
DO YOU WANT A NEW THEME/LOOK FOR YOUR PLAYERwell you cant, if you do not have the official firmware for you player you can not change the way it looks. once again you will need the firmware for your player, and then you will need to modify it yourself
CAN THE FIRMWARE BE EXTRACTED FROM THE PLAYERNO
Sorry this was NEVER possible with these players or any players using the older rockchip RK26 series
please, if it is not broke then don't try to fix it, if it is broke don't try to fix it yourself -
SEND IT BACK
