It is currently Thu Sep 09, 2010 10:04 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: How to unbrick my Onda VX747
PostPosted: Tue May 27, 2008 3:05 pm
Learning Nationite
Learning Nationite
Now i've suddenly got the problem that I can't update the firmware. Now it V1.0, but with the usual method with the volume down button and so on, I can't get the update mode. I've already tried installing from V1.0 to V1.1 and from V1.0 to V1.2 but nothing happens, it just boots normally. Before I always managed to install the new firmware.
PostPosted: Tue May 27, 2008 7:39 pm
Supreme Nationite
Supreme Nationite
Try renameing the file to SG301.hxf
Hybrid firmware for Vx747 and Vx777 bbe audio v1.1B _Linux for VX747_RockBox for VX747-_OS-81 #18284 Custom sig by The Warrior Poet
PostPosted: Wed May 28, 2008 12:09 am
Supreme Nationite
Supreme Nationite
deja wrote:
i realised how much of a mess that site is in (if u dont understand chinese)
so here, i uploaded it to my private server:
download writer tools from: http://code.doubleukay.com/vx747writer.rar
download a copy of the VX747 V1.0 firmware from ftp://ftp.onda.cn/download/driver/oamp3 ... _v1.00.rar
extract both files.
1. plug in your player and make sure that its under CHINA CHIP USB LOADER mode (check by clicking "safely remove.." icon in toolbar
2. load up the VX747.exe from the unzipped folder.
3. my print screen isnt working so i drew you up a quick diagram:
4. click the '...' next to where i wrote FIRMWARE HXF file, and load your V1.0 VX747 firmware file.
5. click BUTTON 2 and leave it. if it works, you should see the blank big box show some writing and a bar in between the bottom two buttons appear.
6. if your vx747 shows the usb connected screen, good.
7. reset your vx747 using the pinhole, while holding down the volume - button, this should reflash the firmware.
8. after upgrade complete, your vx747 should be good to go.
please note im writing this guide on the experience with my VX757, im pretty sure that the methods are similar though.
Nice find here. I did not half to go this route. But I was glad to add this to my software collection. Thanks!!
PostPosted: Wed May 28, 2008 5:22 am
Learning Nationite
Learning Nationite
Hey guys now I suddenly got another problem. I tried installing the modded firmware from eko (ekomp4vx747) and now it is installing it and only comes to a third of the bar and starts again:S
Does Anyone know what i can do aboout this?
PostPosted: Wed May 28, 2008 6:00 am
Insane Nationite
Insane Nationite
Thats happening to me as well, i disassemble the firmware and folder hierarchy is not right.
PostPosted: Fri May 30, 2008 5:15 pm
Newbie Nationite
Newbie Nationite
hi. I have a vx747 that came with v1.1
I upgraded the firmware to 1.2 and now it is telling me unknown file type for videos that played previously and my mp3s just sit there and stutter without playing properly. Also if it does try to play a video it locks up and I have to reset it.
Any suggestions?
PostPosted: Fri May 30, 2008 5:30 pm
Insane Nationite
Insane Nationite
when you repack your HXF, MAKE SURE that THUMBS.db is not included. that screws up the hxf.
PostPosted: Fri May 30, 2008 9:57 pm
Newbie Nationite
Newbie Nationite
Ok I didn't pack/repack it myself (don't even know how). I downloaded the file straight from Onda's site, transferred the file to my unit like instructed in this thread and held down the volume down key until the bar showed up and it updated itself seamlessly.
I've been playing with it and music files stop half way through. Some video files load and then crash the unit. Others just don't load at all. I haven't even tried pictures yet.
PostPosted: Sun Jul 06, 2008 4:04 pm
Casual nationite
Casual nationite
Hi,
Does anyone know if this will work for the VX777 as i have been having similar problems.
I downloaded the progran but was only for the 747 i hope they have created a newer version please help as i go on holidays soon and need music to keep me sane.
Video: VX777 4GB+8GB class6 SDHC Nice palyer, Bad UI
Audio: S:Flo 8GB (Love It)
Phone: N95
Future owner of either N96, N85 or Touch Diamond/HD/3G
PostPosted: Sun Jan 04, 2009 11:17 am
Newbie Nationite
Newbie Nationite
Please can you post a link for same software for VX989+
Mine is bricked also (white screen)
Thank you
PostPosted: Sun Apr 19, 2009 4:28 pm
Newbie Nationite
Newbie Nationite
extract both files.
Perfect for me that don't undertand Chinese, but my plyer is recognized as China Chip PMP USBDISK USB Device and not the China Chip USB Loader
How can I make it so?
Thanks
PostPosted: Sun Apr 19, 2009 7:30 pm
Supreme Nationite
Supreme Nationite
With the player off. Hold the M button while turning on. The screen will remain black.
Hope this helps.
PostPosted: Mon Apr 20, 2009 6:15 am
Newbie Nationite
Newbie Nationite
Hope this helps.
Thanks a lot! Managed to reach loader mode. But the burning tool for the vx757 loops for hours without any success... Missing something?
Thanks
PostPosted: Mon Apr 20, 2009 6:38 am
Online
Moderator
Moderator
are you on XP or vista, vista does not really p;layer well with these programs
Custom dock icons | The Rockchip modding Guide and Tools
OS72HR ::hints tips tricks, links reviews and more
S:Flo² ::hints tips tricks, links reviews and more
PostPosted: Mon Apr 20, 2009 7:14 am
Newbie Nationite
Newbie Nationite
Tested on Vista x64 and the drivers (obviously) wot work...
After I started it on a Windows 2000 old laptop... Here I get the loop... Could this be the problem?
Thanks again
Users browsing this forum: MSN [Bot] and 4 guests
Search for:
