It is currently Fri May 24, 2013 12:32 pm
Post new topic Reply to topic  [ 9 posts ]
 Post subject: scaling question
PostPosted: Thu Jun 10, 2010 11:07 am
i have been converting dvd's to my G85 quite successfully for weeks now.
i just got in 3 new dvd's and performed the same process i always have.
But when i view it on my G85 or 9000HDA this time the video is trimmed on the top and bottom. Nothing i do will get me full screen. I am converting them to 800x480 and have tried every other format size and still the same thing. The only thing i can think of is that i restored my computer and when i reinstalled GOM encoder, it needed to find a codec for the .vob files. is it possible i got a bad codec that is doing this ?
 Post subject: Re: scaling question
PostPosted: Thu Jun 10, 2010 11:23 am
When you re-installed your GOM Encoder, did you go back and change the settings to what you previously had? I know in the settings, on the video tab, there's a selection, "Stretch video to fit the output size".
PostPosted: Thu Jun 10, 2010 11:24 am
Just so it's straight in my mind, are you saying that both players have black bars at the top and bottom of the screen? If so, then you need to set your encoder to remove the borders when you encode video. The Warrior Poet uses GOM encoder, I'm sure he can tell you which option it is you need to set.
EDIT: he beat me to it!
Home Viewing: Assassin HTPC (i5 3570k 3.4 GHz w/ HD 4000) + Samsung UN32EH4003
Portable Audio: Cowon J3 + Brainwavz M3
Portable Video: Google Nexus 4 + Brainwavz M5
Other Toys: WDTV Live Streaming, Xtreamer SideWinder3, Sansa Clip Zip
How to Encode: Blu-Ray to HDVP-2 | DVD to HDVP-2 | DVD to S:Flo²
How to Get Help With: Files That Won't Play | Remuxing An MKV File
Tools: MakeMKV | DVD Catalyst
PostPosted: Thu Jun 10, 2010 11:25 am
:mrgreen:
PostPosted: Thu Jun 10, 2010 7:41 pm
thanks for the tips guys.
yup, tried that. in fact i printed screen shots of every tab before the restore just in case something like this were to happen.
I will have to look around for that, i dont recall ever seeing that option.
PostPosted: Thu Jun 10, 2010 10:21 pm
Code:
I cant find this.
PostPosted: Fri Jun 11, 2010 2:01 am
I just had a look at their help file online. The options you are looking for are the "Output Settings".
Here's a screenshot, it's the "ratio" dropdown box you're looking to change, along with ticking the box to make it stretch it.
PostPosted: Fri Jun 11, 2010 5:36 am
Great response and thanks for the time in doing that! Yes i did try that and nothing helped. For what its worth i also tried 4 other programs i have on these 3 DVD's and they all did the exact same thing. No matter what i did i could not get the vid to fill the screen. SO, i restored the computer back again and this time it worked, Go figure!
SO tonight i will be watching a good movie on my PVP 8)
Thanks again guys for the great help!
PostPosted: Fri Jun 11, 2010 7:56 am
Good to see you got it going again.
