It is currently Wed May 22, 2013 4:53 pm
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Tue Feb 21, 2012 2:45 am
As in the object, I've to open my B2's, without damage them, to a proof clean. Some help?
TIA :lol:
PostPosted: Tue Feb 21, 2012 11:32 am
If you open the B2, the drivers will also come out, they will snap from the wires leaving your unit not working and the warranty invalidated.
I also don't think you need to open it, the nozzle hole is really small and there is a filter inside, this will stop earwax and dirt from getting into the main housing. You could just use a thin pin to pick out any dirt caught inside the nozzle.
Again i really do not recommend opening your earphones.
