It is currently Thu May 23, 2013 12:47 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Sep 05, 2010 1:15 pm
Hang in there popups keep trying Oh and when I said leaving it alone for a day i mean a day(24 hours). Have patience because leaving it alone overnight might not be enough.
Unboxing of Window G85 & Newsmy Momo M-toucht + PT2
Review of the Ainol V6000HDT (Updated: 09/06)
Unboxing of the Nationite HDVP-1
PostPosted: Mon Sep 06, 2010 3:38 pm
Still does not work. Used three different computers -- Windows XP and Windows 7. It does not do anything. The computers do not notice it was plugged in. I think it is truly dead. I waited for the battery to die, still nothing. Now what do I do?
PostPosted: Mon Sep 06, 2010 7:44 pm
I'm not sure sorry,
When mine didn't work leaving it alone and letting my battery drain fixed it, I don't know what's up with yours.
When you plug it in, right click "my computer" and click on device manager, is there a yellow icon anywhere?
PostPosted: Mon Sep 06, 2010 9:35 pm
Did you try the button pressing sequence in the "If your player appears dead section"? I still say it's recoverable. Very rarely is a player an actual brick. Here's some USB recognition techniques, if you want to give that a go: viewtopic.php?f=69&t=16086
PostPosted: Mon Sep 06, 2010 9:46 pm
Dang how many guides have you made TWP?
PostPosted: Mon Sep 06, 2010 9:48 pm
Not sure. Around 20 I think.
PostPosted: Tue Sep 07, 2010 10:02 am
I been trying those guides since the beginning and nothing. I tried both. It has been about four days trying.
The player does not become recognized at any point by the computer. Drivers do not seem to be the issue or the computer or the cable. It appears it is the player. I pressed the button sequenced countless times trying to get it to work. I tried so many times, I think the average person would have given up or become very enraged.
The player does not appear to be on, therefore I believe it is bricked.
PostPosted: Tue Sep 07, 2010 10:10 am
Well, there's certainly that possibility, but I still think it can be fixed. Have seen this too many times to think otherwise. Someone thinks it's finished, then all of a sudden it works.
BTW, are you using an XP machine?
You can always open up a support ticket: http://www.mp4nation.net/support/
PostPosted: Tue Sep 07, 2010 12:06 pm
Have two Windows 7 machines and one XP.
So you have had a player that does not turn on at all "magically" come back to life?
PostPosted: Tue Sep 07, 2010 12:17 pm
Not personally, but yes. Here's one instance. 9000HDA, same chip: viewtopic.php?f=4&t=18617
