It is currently Sat May 25, 2013 11:39 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Sep 04, 2010 12:56 pm
I was trying to change firmwares… The device not found prompt came up, I plugged it in and the update process started. I didn't close the prompt -- the update seemed to stop at 40%. I then closed the prompt and the update process either stopped or finished, I'm not sure. Now the player doesn't get recognized by the computer and doesn't turn on. Usually when this happens at least the player is recognized, then I would just have to reinstall the driver.
PostPosted: Sat Sep 04, 2010 1:04 pm
Dude don't worry keep trying.As long as no cables are loose or nothing you should be able to revive it.
Unboxing of Window G85 & Newsmy Momo M-toucht + PT2
Review of the Ainol V6000HDT (Updated: 09/06)
Unboxing of the Nationite HDVP-1
PostPosted: Sat Sep 04, 2010 1:12 pm
Hold the power button while you plug the USB connection in---this should get the computer to recognize the player as a new drive.
Players: Ainol V8000HDW, Ainol V6000HDT
MID/Tablet: IPad 64gb Wifi
Computer: Dell Studio 15, HP Elitebook 2530p
Music: Sansa Fuse (8gb), Creative Zen (8gb) and Apple Ipod Classic (120gb)
IEM: Brainwavz M2, Brainwavz M3 (thnx Raz), Shure SE310, Etymotic ER-4
Cans: Grado SR225i, Sony MDR-V6, Beyerdynamic DT 770, Koss Portapro
Amp: FiiO E5, Boostaroo, Audiophile Fubar III
PostPosted: Sat Sep 04, 2010 1:13 pm
viewtopic.php?f=69&t=16905 You'll get it, be tenacious.
PostPosted: Sat Sep 04, 2010 1:25 pm
I did the same think on my HDW--and that trick worked for me. After that, I have been reluctant to mess around too much with firmware--unless there's a major improvement.
PostPosted: Sat Sep 04, 2010 1:29 pm
Go to the guide I posted, and scroll down to the "if the player isn't recognized" section. Hang in there, you'll get it.
PostPosted: Sat Sep 04, 2010 1:55 pm
I been trying for about an hour. Nothing is happening. The other times when the player wouldn't turn on, it would at least be recognized by Windows and would be listed in remove hardware on the taskbar. This time nothing happens. Doesn't appear to be on in anyway and other computers do not recognize it at all. No dialog comes up asking to install drivers.
PostPosted: Sat Sep 04, 2010 2:01 pm
Like I said, go to the "If your player isn't recognized" section of my guide, and keep doing it until you get it.
PostPosted: Sat Sep 04, 2010 2:16 pm
Also do check the USB cable you are using, this can affect updating and try using a usb port located on the back of your device.
PostPosted: Sat Sep 04, 2010 9:53 pm
Yeah, that's a problem I had doing a firmware update before, I used a different USB cable and it worked for me.
