It is currently Sat May 25, 2013 3:37 am
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
PostPosted: Sat May 09, 2009 2:24 pm
I wasn't exactly sure where to put this so I hope it's in the right place.
Ok, so the other day I had to put my mp4 in my bag because I was jumping off things and I didn't want to damage it. Later when on the bus, I retrieved my mp4 player only to find that the little cushiony things had come off of the main earphone. I searched throughout my bag and only managed to find one. So my question is; where can I get the little cushiony things? Is it possible to buy them separately? I know they came with spares, it's just I would rather not have to buy a new set of earphones just because I ran out of plugs.
PostPosted: Sat May 09, 2009 3:46 pm
i've seen them in a local electroshop here in my town. they sell them per 3 different sizes, some major brand.
something like this, cost 3 euros
google is also very helpful ;)
http://www.google.com/search?hl=en&q=ea ... s&aq=0&oq=
Nationite OS-81 4GB
PostPosted: Sat May 09, 2009 8:09 pm
Ah thanks. I wasn't sure what they were called. Now to see if there's some near me. Or on eBay.
EDIT: Ok, so I had a look around and the only place I've been able to find them were on eBay. They were almost twice the price of the earphones themselves.
PostPosted: Sat May 09, 2009 10:26 pm
get some replacement "Ear gels' from skullcandy, or foams tips from comply
either is under $10+ shipping
Image Screen Size Comparison
PostPosted: Sun May 10, 2009 2:03 am
twice the price? thats like 30 dollars no man, you must have the wrong ones. these things cost a couple of bucks, at least the ones they sell in my local store are..
Nationite OS-81 4GB
PostPosted: Sun May 10, 2009 2:54 pm
Also make sure you get the right size, if they are too small they won't fit on the driver shaft
PostPosted: Mon May 11, 2009 4:07 pm
The back-up ones sent were almost too small -.- A friend told me that JB hi-fi sells them so I'll have to check that out. I had found them on eBay for $10 but postage was $40.
PostPosted: Mon May 11, 2009 4:33 pm
maybe mp4nation sells spare ones? try and send them an email
Nationite OS-81 4GB
PostPosted: Wed May 13, 2009 11:47 pm
Just buy some really cheap in-ear headphones and take them of those.
Loving Nationite.
EhmPeeFor Gadget and Technology Reviews
-Nationite OS-81
-Nationite S:flo (out of phase)
-Newsmy Momo M-touch
-Onda Vx525
-Onda Vx767 (broken)
PostPosted: Thu May 14, 2009 8:11 am
OK, you have many options. Depending on were you live, in the usa, you can get them at radio shack, I just bought some new rubbers there, $3.00 bucks.
Users browsing this forum: Google [Bot] and 0 guests
