ok guys..i have some great news....
my m-touch has now 9 new games
after a lot of searching...i found a cab installer which installs games on the m-touch from cab files. how to do it:
download this cab installer:
http://rapidshare.com/files/115383538/cabinstl.zip.htmlcopy the cabinstl_en.exe somewhere on your m-touch and you will be able to run it from there
download these cabs (9 games):
http://rapidshare.com/files/115384158/G ... S.rar.htmland copy the cab files in different folders on the m-touch (for example in folders cab1,cab2, etc)
now run cabinstl_en.exe on m-touch .... you will have there cab and path..click on cab and select the first cab from the folder Cab1 (when you click on cab button it will take you to the main folder of the OS, you will find your files in the folder VDisk) ....click ok
on path, it will take you to the folder of the cab..click on the icon for "new folder" and then doubleclick on the New Folder..then ok
then click install in cabinstl ...and it will ask you something in chiseese..click on the option which starts with Y....and it will install the game in the folder New Folder from Cab1 folder..
you can exit cabinstlr now and go to Cab1..then NewFolder..and run the game..
the same for Cab2....up to 9...
after this..you can edit the folders from windows by connecting the m-touch through usb cable...and you can delete the cab files and keep only the installed games....
i also uploaded the games already installed..you may try them as they are...but i am not sure if they will work (i'm not sure if they are distributable)...that's why i gave you the tutorial above....here is the link:
http://rapidshare.com/files/115386009/Games.rar.htmlyou can find info and cabs for the games here:
http://www.xflib.net/index.php?action=games&allgames=1i took all the games which are compatible with m-touch from this site...as a matter of fact..all of them run on m-touch...but some of them are 240x320 and are distorted...making the m-touch unstable (i had to reset it)...but the ones i uploaded for you are 320x240...and fit the whole screen...
i also tried some cab files from other sites...for some popular games ..like Syberia, Tomb Raider...but somehow cabinstlr can't install them....or if it can install them...they don't work when I try to run them...so they might not be compatible with m-touch...
so..if any of you know some websites with applications/games with cab installers (this way we can avoid using active sync to install them)....please try installing them by using the tutorial above...and give links for working games/applications
cheers
edit: i played the games (applications) a bit...so I could say that Pocket Gravity misses the down menu (it is black)..but you can still draw squares falling ..it is very interesting...
chain reaction is 240x320 so it doesn't fit the whole screen..but it is playable and the m-touch doesn't get unstable... the same with Virus Chaser...
the games i like most are hexavirus and perpetual (this isn't actually a game...is a very interesting image viewer)...enjoy
