It is currently Sun May 19, 2013 5:06 am
Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sat Oct 18, 2008 7:36 am
Please, I need help.
I have a onda vx777, bought yesterday, I put music, but after teh player did not open the folder in My Computer, gives an error message that the disk must be formatted, but the formatting is not made until the end, gives an error before.
so I did download a program from HP, which formats the USB, it is called "HP USB Disk Storage Format Tool", but even with that program he only format for NTFS and FAT32 is not enough to end and gives the same error message.
Can I make it back to the original?
NOTE: He does not transfer any kind of file to the folder ...
What can I do?
PostPosted: Sat Oct 18, 2008 12:23 pm
Anybody??
PostPosted: Sat Oct 18, 2008 12:33 pm
Hope I understand this right....
The player [vx777] wont 'play' any music?
1. When trying to select music to play, was the icon for the music player selected?
On this player if you select 'video' for instance and go to the music folder...it wont play the music, as it is looking for video files.
2. Your PC is saying that vx777 needs to be formated?
If you have nothing on it - or it dont play, as seems to be the case, go ahead and format it.
It wont hurt the player, BUT, any files you put on it will be lost.
Format to FAT32 and use the FULL.
PostPosted: Sat Oct 18, 2008 12:48 pm
Yes, my PC ask to format the player, but when i will gona do that, the formatting don't end, windows say that the player can't be formatted...
See that:
I'm from brazil, sorry about my english.... my windows is in portuguese, i will try to traslate these warnings.
1-
In that print, i click on "SIM" its mean "YES".
2-
I click in "INICIAR" its mean "START"
3-
Apper these warning, its mean "The windows can not complete the formatting"
4- Click in OK, and the last massege is that:
"The hard drive "E" can be formated"..
Hope you understend my problem.....
Everything i will gona do in player, these messeges appers, and i can do nothjing.
PostPosted: Sun Oct 19, 2008 11:11 am
Hellllp!!!!
PostPosted: Mon Oct 20, 2008 2:16 pm
From what I can see in your pix, you seem to be doing it right....
May try the 'Quick' format....
If that one dose work then do it again using full format.
If not.....May be a bad player - or, at least the memory on it.
I have not seen....any vx777, that could not be formated though.... :(
PostPosted: Tue Oct 21, 2008 9:20 am
Doesn't work, the player not formatting.... I don't know what i can do....
PostPosted: Sat Oct 25, 2008 5:54 pm
1) try a different USB cable
2) try it on a different USB port or PC
This type of error normally is from a faulty cable or port. You can verify that its not memory, if the player turns on fine and you are able to use the sample video and audio files, then the memory is working fine, if corrupt then the player wouldn't even start properly.
