It is currently Fri May 24, 2013 10:23 pm
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Wed Apr 30, 2008 9:02 am
There is a green screen that comes up on my meizu player every time I turn it on it says No Resource! Please Upgrade Resource Again! It pops up right after the loading.... message. I plugged it into my computer and all of my files have been deleted every folder is empty all of my music files are gone and everything that I have recorded. The arrows don't even pop up when I connect it to my computer as well as the battery icon when the player is charging.
Can someone help me I don't know what to do I tried putting more music on my player but can't pull any thing up because it doesn't go past the green screen but the music does show up in my music folder?
Thanks in advance!
Music Diva
Current Players:
Meizu m6 SL (black) recieved in 9 days
PSP (1st gen)
Players shipped for repair:
4GB Hacha PA20
PostPosted: Wed Apr 30, 2008 1:27 pm
somehow you have done a hard resrt on the player, this can happen by pressing a combination of buttons or freak accident (never to me before)
you need the "resource" ile that has all the images for the user interace as the player has lost them
did you try to update the firmware
go here
http://en.meizu.com/down_x.asp?MZ_ID=137&Type=2
and follow the instruction to install the new firmware and al should be ok
a hard reset will format the player so all files wil be lost, but if this happend on its own you need to monitor this and see if it happens again as these players are quite robust and shoul not do this
PostPosted: Wed Apr 30, 2008 9:31 pm
It just happened on its on. I didn't know how to upgrade the firmware so I didn't upgrade, but now thanks to the link you provided I will try it. There was no accident I don't know how it happened. But I will try to do as you say and I will post wether it worked or not
Thanks again!
Music Diva
Current Players:
PSP (1st gen)
4GB Hacha PA20
PostPosted: Thu May 01, 2008 11:13 am
It worked! :D I had to figure alot of stuff out I didn't know WinRAR had to be installed on my computer inorder for me to upgrade the firmware that is where I was confused. This is my first time learning about all of this and I figured it out thanks again maderin 1.
Music Diva
Current Players:
PSP (1st gen)
4GB Hacha PA20
PostPosted: Thu May 01, 2008 12:37 pm
well done, but keep an eye on this.
i also have a new SL version meizu too so hope it is stable, my sp was solid as a rock
glad its al back workin no though - good work and new skills learnt
