onda vx858LE
budubum
onda vx858LE
Postby budubum » Mon Feb 11, 2008 2:29 pm
hi all.
im new here.
i wonder if someone could help me find a firmware upgrade on my original ONDA VX858LE mp4 player.
thanks in advance.
vx858
Contact:
Re: onda vx858LE
Postby vx858 » Mon Feb 11, 2008 8:26 pm
budubum wrote:hi all.
im new here.
thanks in advance.
The original ONDA VX858LE V1 & V2 both use the v1.0.40 firmware, which is currently the latest for the original VX858LE.
I collected all the firmware and made a pack containing all of the firmware, download it and use the VX858LE firmware: http://www.megaupload.com/?d=NN2AQJDO
You will have to use a program called ConsumerUpdate, you can download ConsumerUpdate_3.1.0.0 if you don't already have it: http://www.megaupload.com/?d=ISACU6HX
My primary device: Apple iPod touch 8GB (2nd generation) with iPhone OS 3.0 software update (jailbroken with redsn0w)
budubum
Re: onda vx858LE
Postby budubum » Mon Feb 11, 2008 11:56 pm
thanks man..
i also forgot that i have the v2 4GB verrsion of the player.
have u tried a 4GB mini SD card?
just wanted to point out that the kingstson 4GB SDHC class6 WONT work with the device. it only leaves it hang up and must tickle the reset botton for the player to turn off.
Raz
Re: onda vx858LE
Postby Raz » Wed Feb 13, 2008 6:27 pm
i don't think 4GB miniSD cards can work, i believe the idea was that a future firmware update would allow for 4GB support, but it never came.
budubum
Re: onda vx858LE
Postby budubum » Fri Feb 15, 2008 6:57 am
hehe ok. hope that firmware would come true:P
TY anyways.
Player crazy
Re: onda vx858LE
Postby Player crazy » Thu Feb 28, 2008 10:05 pm
I use a 4gb mini SD in my VX858LE clone and it works perfect !! it's a kingston one too !! But it's a non HC card !!
My players :
2GB Onda VX878 v2. ver:02.00.0007, Onda sent me a new one. yippe !! :)
2GB 858 clone, 4GB kingston mini SD, ver:00.00.0020, with updated screens (Now with cracked screen)
2GB Base MP715ss. ver:2.620.002
Madhoax
Re: onda vx858LE
Postby Madhoax » Sat Mar 01, 2008 1:32 am
Player crazy wrote:I use a 4gb mini SD in my VX858LE clone and it works perfect !! it's a kingston one too !! But it's a non HC card !!
Where did you buy that card? I am looking for a 4gb card that works with the generic player, but I can't seem to find one. All 4gb cards are SDHC, and I have read that the non SDHC cards can only contain a maximum of 2gb because they work with the fat16 structure.
The old standard for minisd cards was 2gb (sd 1.0 and 1.1) The new standard, sd 2.0 can read and write minisd cards to a maximum of 32 gb. So if the generic (onda) player doesn't support sd 2.0 the maximum minisd you can put in there is 2gb right??
Nationite S:Flo 4gb (lost it :S)
Onda VX777LE 8gb
Madhoax
Re: onda vx858LE
Postby Madhoax » Sat Mar 01, 2008 2:28 am
I looked into it a little further, but it's impossible to put a 4gb card in the generic player....
http://www.kingston.com/flash/pdf_files/MKF_1127_SDHC_Topic_Paper.pdf
There are no 4gb non-hc cards out there. All cards above 2gb are hc and using SDA 2.0. I think the generic player is using 1.0 or 1.1
Onda VX777LE 8gb
t0nito
Re: onda vx858LE
Postby t0nito » Sat Mar 01, 2008 3:11 am
Madhoax wrote:I looked into it a little further, but it's impossible to put a 4gb card in the generic player....
Here's a non SDHC 4Gb card
Madhoax
Re: onda vx858LE
Postby Madhoax » Sat Mar 01, 2008 3:26 am
t0nito wrote:Here's a non SDHC 4Gb card
Thanks for the link :) But that's a lot of money for a minisd. It's almost as expensive as the whole player :P lol.
2gb minisd's are 4 times as cheap as these babies. Think I will go for the 2gb cards instead.
Onda VX777LE 8gb
Return to “Tablet, Smartphone & Media Player Discussion”
