It is currently Wed May 22, 2013 1:27 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
PostPosted: Thu Jan 20, 2011 4:34 pm
Hello all. I have another problem with battery. First - battery drain in poweroff device - near 10 % per night. And second if i not charge near 3-4 days - time reset to the 01/01/2000. Anybody have suggestions?
PostPosted: Thu Jan 20, 2011 5:37 pm
When your time resets on the MIDnite, is this if you leave the battery in the MIDnite, or if you take the battery out of the MIDnite for 3-4 days?
Totally lacking in sense and style.
Ingenuity™ by maderin1 - The New Fragrance
PostPosted: Thu Jan 20, 2011 6:20 pm
Battery always in Midnite.
PostPosted: Fri Jan 21, 2011 10:29 am
Do you get the same behavior if you leave the battery out of the MIDnite for 3-4 days?
PostPosted: Fri Jan 21, 2011 1:15 pm
i try another battery with similar behavior, but can't try without battery. I try and write again.
PostPosted: Fri Jan 21, 2011 1:25 pm
Its probably because the battery is discharging, for best results please remember to charge your MIDnite every night when asleep.
PostPosted: Fri Jan 21, 2011 4:06 pm
That mean - it normal behavior with discharged battery ? This need to write in FAQ. If it's abnormal - i want help :)
PostPosted: Fri Jan 21, 2011 4:27 pm
It is known that if the battery is left in the MIDnite it will lose a charge.
However, this is the first time I've heard of the date resetting.
Have you tried upgrading the firmware and seeing if the date resetting issue persists?
PostPosted: Fri Jan 21, 2011 9:53 pm
i reflash my Midnite with all firmware and with all i have time reset. i recieve new battery - and have similar behavior. Very sad :(
This morning i leave midnite without battery.
PostPosted: Sun Jan 23, 2011 4:06 pm
Now? after near 40 hours my Midnite without battery, i put battery and see time reset again. :(
