It is currently Sat May 25, 2013 6:07 am
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Windows XP 64bit
PostPosted: Thu Oct 28, 2010 4:28 am
HI,
I've tried the search function and apologies if it's stated somewhere.
It mentions compatible with windows XP, but has anyone tried with the 64bit version of XP. That's what I've got and loads of things don't work with it.
 Post subject: Re: Windows XP 64bit
PostPosted: Thu Oct 28, 2010 4:42 am
it should work as in connecting and being able to transfer files etc, don't think we have had a 64bit windows xp user, definitely had vista and win7 though
only thing is firmware updating, 64bit systems have proved difficult for most, some have used the update tools to update the player on win7 64 but i could not get it working
so for updates you may need to ask nicely of a mate and borrow a 32bit XP machine
anyway, for general use and files copying etc it should be fine
welcome to the forums
maderin1
PostPosted: Thu Oct 28, 2010 5:09 am
Thanks for getting back to me, I can borrow a 32bit XP laptop for updates I think, but good to know these things. Winp XP 64bit is the OS the world forgot!
PostPosted: Thu Oct 28, 2010 5:37 am
yep, must admit i had a moment when i saw XP and 64BIT, didnt computer for a moment, it should be fine though for general connection and file transfer
cheers and welcome
PostPosted: Thu Oct 28, 2010 9:50 am
I have an S-flo2 and an AMD 64 bit computer with XP. There have been no problems with them. However, Window's 7 created problems with my S-Flo and my OS-43. XP with either a 32 or 64 bit AMD or Intel PC worked fine with both of my players. I cannot comments on an Intel 64 bit PC with XP as I never have one.
The 300 Spartans were NOT defeated,They were Only killed
Without Imagination, You're Doomed to Live in Reality -Einstein
Without Music & Dreams we live without Imagination -DrinkingStar
There is no place like home, except Grandma's
Kindness is the noblest weapon with which to conquer
Moderation leads to mediocrity
PostPosted: Fri Oct 29, 2010 3:51 am
That sounds good, cheers. I have an Intel, not sure if it's the windows XP 64bit (lack of) drivers or I've got dodgy USB ports, but I've found it temperamental at times when hooking stuff up. Will probably be a while before I get the s:flo2, but I'll try to remember to report back.
No drama either way as housemate's old laptop is 32bit XP. :)
