It is currently Thu Jun 20, 2013 3:47 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: SD card
PostPosted: Tue Sep 28, 2010 7:41 pm
Sorry for silly question but how far in is the SD card meant to go and how is it meant to be removed?
There is no 'spring' in the socket - it feels like I could push the card so far in, it would never come out.
 Post subject: Re: SD card
PostPosted: Tue Sep 28, 2010 10:03 pm
Same problem. But I can take it back using scotch (sticky) tape.
Cut little piece of tape (0.5 x 2 cm approx) and try insert inbetween SD card and slot (sticky side to card).
Hope it will be helpful.
PostPosted: Tue Sep 28, 2010 10:07 pm
Stupid question but you are putting it in the right way right?
PVP: Ainol V6000HDT 8GB
Music: Sansa Clip+
Tablet: iPad 3G
IEM: Brainwavz M3/ M1
Phone: LG Optimus 2X
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost. That is alchemy's first law of Equivalent Exchange. In those days, we really believed that to be the world's one, and only, truth. - FMA
PostPosted: Tue Sep 28, 2010 10:18 pm
Your "print" could be stuck in the inner postition (happened to me on another SD-card reader not the MIDnite), use above tip to use a piece of tape on the top of the card, and then push it in as far as you can, hopefully you will get the sprint to spring out, if not, well you have to keep doing it the tape-way :)
http://www.AndroMIDs.com - Firmwares, Custom ROMS, apps, howtos for the MIDnite and other Android MIDs.
Current setup:
MID: Nationite MIDnite (loving it (did after 5 minutes))
Portable Musicplayer: Nokia 5800 with Philips Bluetooth headset, Onda VX530 (mostly used by my daughter)
Video and Music player: Laptop with radiolink to multiple speaker systems, also Bluetooth connection to speakers (Belkin bluetooth reciever)
Nationite HDVP2 streaming from a Server with 2,5TB of music, movies, tvseries and photos via TVersity (trying it out)
PostPosted: Wed Sep 29, 2010 8:09 am
Thanks for the tip Rucha - will do.
I thought I'd actually done this but no, it is in the right way. I was able to flash to ADEPTUS' FW from the card.
PostPosted: Wed Sep 29, 2010 8:33 am
Ahh ok, never had that kinda problem myself, once put a Micro SD card in the wrong way in a phone.. lol :P
Music: Sansa Clip+
Tablet: iPad 3G
PostPosted: Wed Sep 29, 2010 4:51 pm
The SD card does go in quite a bit so that it does sit recessed. Normally i use the nail on my finger to get in there to push down on the card, when you do that you will hear a click and it will pop out. People with big fingers may find it a bit hard to get your card out.
PostPosted: Wed Sep 29, 2010 5:52 pm
Thanks, I'll try that.
PostPosted: Wed Sep 29, 2010 6:55 pm
I use slylus for this. But I don't hear any click and SD card doesn't come out. Only scotch can help.
Very cheap slot. :(
PostPosted: Wed Sep 29, 2010 6:58 pm
There is a click when it goes in and click when it comes out, the sound is very faint, but the click is the locking mechanism, without it the card would not sit in place properly.
